JayXSP
A couple days ago I purchased an efan harness from another member on here. Shortly after I received it I realized that its the dual pin 03+ harness. I need the 00-02 single pin harness.
My question is, is it possible (easy) to rewire harness to work with my truck? Possible to change the AC trigger on this harness from the negative PCM trigger to the positive AC trigger? I read somewhere that a guy added a relay to a factory 05+ harness to make it work with his 01.
If its too much work I'll just re-sell this harness and purchase the one correct one...but If i can modify this one it would be great.
I sent Justin an email but haven't heard back...figured this would be easier
thanks in advance for any info you can supply
-Jay
-Jay
