E85 on non E85 tahoe
BG1988
will e85 work on a non E85 tahoe? i'm tired of paying 5$ for gas e85 is only 3$ a gallon
St. Louis
Don't you get like 40 bajillion miles per gallon on that thing?
Everyone says (well, everyone who hasn't run E85) that your mileage will tank and the cost difference isn't worth it :rolleyes:
TVETTE
If you don't have a yellow fuel cap don't even think about running E85 !
I have done a long term fuel economy test and I am only loosing about 1.4 miles per gallon with E85. I just filled up the other day, my lite was on and took about 22 gallons, I saved about $24 verses gasoline price here in Ca.
donjetman
For 6 mths, I ran a mixture of E85 and regular unleaded in our 6.2 Denali. Everytime I filled up (20+ gals), I would pump 3 gals of e85 then fill it the rest of the way with regular. The addition octane in e85 makes it possible. Works great for me and saves a little $.
B
BG1988
even if it gets 2-3mpg less it will still be way cheaper to run e85
e85 is 3.59 a gallon (has been since 2020) while regular is 6-7 a gallon depending on the station
intheburbs
SE MI
Seal guy here - O-rings, gaskets, etc.
E85 affects rubbers differently than gasoline. If you run E85 in an engine not designed for it, you'll likely have damage/leaking in your hoses, gaskets and seals.
super_kev
