vanilla_gorilla312
- Joined
- Nov 24, 2009
- Posts
- 62
- Reaction score
- 0
I noticed a few days ago I was driving and all of the sudden all the electrical stuff in the car, ie. stereo, gauges, etc., just shut off and turned back on again, but the car kept running. It was just like when you first put the key in and started it up, as far as the gauges and stereo go. The a day later I noticed it was a bit hesitant to start and has been. It cranks fine, but as soon as it starts, the rpm's drop and wants to die again, especially once you put it into gear. Most recently I replaced the starter solenoid and thats about it. Is there a wire shorting out or is it some kind of power relay, or pcm????? Any ideas would greatly help. This friday I will be doing the big three upgrade so will check to see if any of the coating on the wires has perhaps exposed wires causing it to short out. Thanks
