JPVortex
Hello, all my 2005 Tahoe's cooling fans are not coming on no matter what. This is an ongoing issue, that while the truck stays steady at 205-210 while moving, it does climb a bit while sitting at idle for 15+ minutes. Direct 12 volts to the fan shows that they work, so it's wiring for sure.
Tried swapping out all of the relays for known working ones and the fuses to no avail.
Does anyone have a wiring diagram for the fan assembly? May try cleaning up the relay center or getting a new relay center. I may also try finding a ground to clean up.
If I really can't be bothered I'll just wire it to the ignition so it's always on.
