gmartin1215
- Joined
- Nov 9, 2012
- Posts
- 240
- Reaction score
- 103
Hi,
I have an 09 LT that has the factory electric radiator fans. Recently, I have been hearing the fan kick on even though the engine is cold, like just starting for the day. Normally, I don't hear this fan unless its a hot day and I have been idling a lot. So, I am thinking something may be at fault. normal operating temperature has been sticking around 200 deg.
What are some probable causes for this symptons and what diagnostics would you suggest to determine if there is a problem?
---------- Post added at 01:45 PM ---------- Previous post was at 12:39 PM ----------
just adding more info
It is the high cooling fan that comes on. It does it at startup, then shuts down,. And t does it while driving, on off. So, its not constantly on, just off and on. if its running when I turn off the engine, it runs for a short bit longer then shuts off
