1999 Tahoe
Rolled the driver side window down a week ago and then it would not go back up. All of the other windows work fine from their controls and the main driver side control.
Everything up to this point indicated that I had a bad motor. I picked up a new motor yesterday, and decided I would plug it in before installing it just to make sure it worked - it didn't.
I check the voltage with my ohm meter, but I do not get anything when I hit the button. I also tried using my check light - again nothing.
As far as I can tell all of the windows run off of a single 30A fuse, and as I stated above all the other windows work fine.
Not sure where to go from here in diagnosing the problem.
