Y2KpewterZ
- Joined
- Mar 31, 2013
- Posts
- 202
- Reaction score
- 12
Vehicle is a 99 Yukon 5.7 4wd. Long story short bought the truck with a hole in the gas tank unbeknownst to me until I filled it up for the first time. No CEL for a massive evap leak though.
Replaced tank and installed new Delphi pump and ACDelco tank pressure sensor. This caused new issues to arrive. Truck would stumble and sometimes die after re fueling, also truck had a hard time starting after being warm (not a long cranking time, almost like the starter would stop spinning for a moment then kick back around) and p0446 kept popping up and noticed my tank was making a creaking noise and noticed pressure when I’d unscrew the gas cap.
I replaced the vent solenoid (Dorman) thinking that was the p0446 code and the pressurized tank issue. I also loaded the parts cannon while I was in there and replaced the purge solenoid (Standard) fuel filter (Wix) and gas cap. This fix lasted maybe two days until the hard start and stumble after refueling started again.
I disconnected the evap line from the tank that runs to the vapor canister and the truck runs great and no issues, except for the smell of gas. This led me to believe the vapor canister was clogged. Replaced canister (from a PnP, but I could freely blow air into it) and the hot start/stumbling issues were back. The truck would even cut off after idling for a few minutes. I also changed the vent solenoid with an ACDelco unit, still no fix. Unplugged the evap line from canister and truck runs great again.
Ecu issues here or am I missing something? Tia.
