rayninglead
Was just pulling my buddy out and looked down check gauge light was on and had no oil pressure so I shut it off and checked the oil level it is normal. Have 5 to 0 oil psi at idle and around 20+ while driving but there is definitely something knocking from the lower end. Thinking I washed out a bearing or something and it's squeaking from the front end. My buddy says he think the oil pump needs to be changed but from the sounds of it the damage is already done and doing that is a waste. What should I do? What should I check for? I doubt it's something that easy from the way it's knocking. how much would a rebuild be? And I was almost wandering If I can use any 350 block with my upper end thanks for any help you can provide
