Errrr I got a question about brakes help me
01Tahoe
Here
Basically all i did was bleed the rears starting with the right rear then left rear. Then I had to move the car forward so I could do the fronts in the garage. Then I noticed that the pedal was spongy, so I did the rears again only to have the same effin problem?!? If I do the fronts will the problem go away?? This is for a 01 tahoe. Oh and I used the gravity bleed method. Also what is the right way of bleeding the brakes? Furthest to closest or the cross method(right rear 1st, left front 2nd, left rear 3rd, and right front last)
Thanks
waxworkz
you should start the furthest away, so right rear, left rear, right front, left front. i usually pump 20 times and hold the pedal and someone else opens bleeder till only fluid comes out. dont forget to fill the reservoir between bleedings.
01Tahoe
Here
Nevermind I just bled the whole system now everythings fine.
tanguycryms
