Essentially Offroad
musicitytiger
In Murfreesboro tn quoted me $350 for a 2" suspension lift w/ new shocks all installed. Does this sound to good to be true? Also, will this give sufficient clearance for 32" swampers that are 11.5" wide?
Gzes
the drifting 2dr
Wichita tx
Sounds good. I'm gonna get charged $400 to get a body lift installed. N I think u can rock 33s on ur rig stock height as long as its a 4x4
purple 'hoe
Green Bay, Wisconsin
Is this total cost or just labor? Seems about right for labor only.
Tire wise. The tires MAY fit. But a 11.5 is a wide tire for that slight amount of lift. Depending on your wheel ofset if you are running aftermarket wheels or stock wheels. Stock wheels it might work out.
ChrisAU
Birmingham, AL
A 2" lift for that price...they are just going to crank your T-Bars and put blocks in the back.
And if it is a 2"-3" lift, those are all junk and will murder your front end.
