Exhaust rattle issue
draper11
I am getting what sounds like exhaust system vibration at certain levels of acceleration. Tonight, at 1200 rpm under light constant throttle, I almost got it to do it at intervals a few seconds apart. The RPM would lightly tick up as it occurred.
I did have a look under the truck this past weekend. I think the noise is the heat shield before the muffler. I put hose clamps around it which I think lessened the sound. I did not see any vibratory issues with 02 sensors.
Can I be getting some kind of misfire through the system? Do I have a cat issue or some other compromise? Do the rubber exhaust hangers get loose over time allowing excessive shake?
Thanks for any suggestions to look for next.
j91z28d1
I'm pretty badly at finding rattles but if you got a rubber mallet. you can climb under and tap the exhaust with it. you might find your rattle.
hit the cats too, it's possible the brick inside comes loose and rattles around.
rdezs
If you had a misfire or a defective catalytic converter, you'd get a check engine light. But yeah, I like the rubber mallet I keep hanging on the wall. Tap on the catalytic converter as well as the muffler and resonator if you have one. Could be just a baffle inside of the muffler came loose. Those big rubber hangers typically don't stretch out, but get harder with age. Heat shields are probably the number one rattle item..... Speaking of heat shields, check if you're exhaust manifolds have the heat shields on them. I've seen a couple of those come loose and vibrate depending on RPM
CTX-SLPR
College Station, TX
I'm having the same sounds and it turns out that the flexpipe just behind the rear most cat is broken (the outer braiding is swollen). Open the passenger door and start it to see if you get exhaust leak sounds as well.
D
draper11
That’s interesting. My braiding was swollen and loose- so I clamped it- how did you find that it was broken? I did remove the pipe to refit the connector. Is there another downstream before the muffler?
dasdunkelrabe
