Expert towing guys check in:
jesse53
Moving to Florida, 6x12 U-haul which Ill tow fine, But do need towing mode
[higher rpm] all of the time? Or overdrive on flat stretches OK ??
2002 Yukon XL 5.3
livingez_123
Sandy, OR
Well, I guess it depends on how you drive. If your not too heavy, tow/haul might not even be needed. Keep an eye on your trans temp, if it starts to creep up, drop it out of OD, slow down a few MPH and see what happens. Use an easy right foot too.
Rivieraracing
You really just don't want to have your motor do a bunch of lugging around and/or having your trans do a bunch of hunting for gears by excessive upshifting/downshifting to maintain a speed! When those conditions are happening, either slow a bit down or downshift a gear to keep the RPM's up!
JochenWoern
Sacramento, CA
Other than on flat stretches and steady speed, I ALWAYS am in tow mode.
The truck seems to shift just fine in order to avoid what Chris mentioned above. At steady speed on flat stretches of Freeway, I turn the tow mode off and let the truck plus trailer just cruise along.
This technique has always worked well for me.
jesse53
jesse53
Thanks, Ill definately take it easy then, no rush to get there.
---------- Post added at 03:31 PM ---------- Previous post was at 03:29 PM ----------
What part of Florida?
Sent from my SCH-I535 using Tapatalk
Citrus Springs
---------- Post added at 03:32 PM ---------- Previous post was at 03:31 PM ----------
Big Buttons
The SS Burb
South Texas
I towed the same trailer about 600 miles. It was loaded pretty heavy and I also had my 500lbs stereo in at the time. That was over a mountain pass and TX hill country. Just take it easy, use tow/haul for hills and whatnot and turn it off on flat ground. That's what I did and I did fine. My Trans temp never went above 160 but I have a really large cooler though.
dropmech
Puddle Pirate
Coral Springs
I towed the same trailer packed to the max from Cape Cod down to Florida. I didn't really use the tow mode too often. I had the cruise set most of the trip and maintained probably a less than safe speed.
jesse53
jesse53
Cool, thanks for the advice !!! Ive towed in a Penske truck pulling a 1970 Dodge Super-Bee my bud sold on ebay... all the way to Corpus Cristie Tx. So Illl practice backing at an empty K-Mart lot nearby 1st.
1stYukonXL
