2012 XL Denali with OE controller, will not display the trailer is connected, I tested this on a 2nd trailer also.
Trailer lights, signals, and brake lights work, no corrosion on either side of the 7-pin connector.
I removed the kick panel and the controller is connected, also the controller illuminates when headlights are on.
I do have the JL1 RPO code
Fuse #6 is good.
No codes
Pressing the +/- buttons or sliding the lever does not display anything.
Would the relay cause this?
Fuse #6 is good.
No codes
