factory or aftermarket back up camera??
MDC9966
Newton, NC
I just got a factory nav unit for my 07 tahoe with bose. I want to add a back up camera now. I've read a few threads about a box under the passenger side seat to do something??
I don't have this box under my seat. Can I add a camera to my factory head unit? I have the harness with my the RCA plug. Do I just plug it up, get the camera power and switch it on using the back up lights when it's in reverse?
What would be easier a factory camera or an aftermarket one?
Any suggestions of where to buy one and which one to buy including harness needed is appreciated.
Thanks,
I know that's a lot of questions and a lot of people are doing this. I plan to write up with pics my experience in doing this. Currently my head unit is a bose, cd, am/fm/xm unit only. The nav/dvd/am/fm/xm/camera unit is going to be great once I get it in.
Thanks again,
Michigan, Metro Detroit
Did you ever got your questions answered? which option did you go with ? if you can share the info I am about to do the samething you did. Please let me know. Thanks !
MDC9966
MDC9966
Newton, NC
I ended up getting a factory camera off ebay for about about $35 then cutting the plug off and running wires up to my head unit. I pulled power from the back up lights and it worked great. ONE IMPORTANT NOTE: you must use a voltage reducer in line for the camera, stepping down the 12v to 5v. Otherwise you will fry the camera. I know because I did that the first time. At $35 not an overly expensive lesson but a lesson I wouldn't want someone else to repeat.
Good luck
mviinc
Raleigh, NC
You're navigation must have been programmed already for camera?
There are a few options out there for camera...I have done the factory and factory like cameras, what ever you go with will require an input harness into the Nav which I just build myself. Dealer programming will be required though to get the navigation to switch inputs when placed into reverse as that is controlled through the CAN system
MDC9966
MDC9966
Newton, NC
I had to have my camera function turned on at a dealership. The rca plug was already there on mine, all I did was plug up the factory camera and step down the input voltage from 12v to 5v. I think if an aftermarket camera was used it would maybe have been 12v to begin with but I found the factory camera so cheap I went that route. So far so good.
mobial
Hi Anthony - Not to be rude in hijacking this thread, but I'm in this exact boat right now and I'd appreciate some knowledge. My 2007 Yukon's camera went black, and I got a cheap replacement camera that is 12v and works great and has an RCA plug. (THIS ONE: http://www.amazon.com/gp/product/B006N5C0O0/ref=wms_ohs_product?ie=UTF8&psc=1).
Problem is my head unit/nav doesn't have an RCA jack. My head unit is (15882766) and I've been searching and came up with *maybe* I can wire into this brown connector and I've even seen a (camera adaptor) that might be right --- BUT REALLY I just want to specifically know how to do this logically – like if there are wires going from the underseat box up to the head unit ALREADY, why not just chop the RCA ********, connect to them and be done? But which one?
Any info you can provide me would be GREATLY APPRECIATED, specifically what wires/pins I should use and where? (like what pins are written on that adaptor's tag?)
My head unit and underseat box images are attached -- if that helps explain anything... thanks for any help!
kjetilaf
