Failed inspection today
mzr2240
Haven't done any mods, replaced the alternator a couple months ago. Drives great, no issues or lights on the dash. I use a range obd plugin but I took that off and it still failed. Any suggestions?
We've heard that unplugging the Range device can reset some of the monitors, although it seems to vary. Anyway, your pic is showing that there are three monitors that have not completed, and usually you're allowed only one incomplete monitor. You'll need to drive it for a bit without the Range device to get the monitors to set, so be sure to re-check them with your scanner before going back to retest.
What part of the country?
In Jersey all monitors need to be set, if not you fail.
Tonyv__
Bucks county PA
I use a range OBD plug in my Yukon. I’m fairly certain it also caused my systems to fail this past week.
Have to do a drive cycle with the range unplugged then try to get it tested again
M
mzr2240
I'll try driving it around without the range device in, we'll see if that helps. It was failing on 4 monitors but as soon as I unplugged it I only failed for 3. I'm in Tx but I don't know how many I'm allowed to fail here. Thanks guys
Tonyv__
Bucks county PA
I don’t think any emission states will let you fail any of the test.
petethepug
Michael
SoCal
Here’s the work around to manually reset the equipment. I had my Tech2 plugged in during the drive cycle so that after each drive cycle I could verify the BCM showed success.
Tonyv__
Bucks county PA
Probably true. But we're talking not about failing, but monitors being ready.
Yeah I agree we got off track with the terminology. But monitors that aren’t set would be a fail in the eyes of the inspector if I’m not mistaken
But no need for diagnostics, just need to complete drive cycle
Boosyed96GSX
