jdub5256
J-DUB
OK so i decided that i wanted all my strobes in my tahoe front n back. the biggest thing was where did i want the switches! I really wanted something that looked completly factory cause after all this is a really nice interior. so i decided to use the homelink buttons in the overhead consule. let me tell you very time consuming and lots of trial and error.
1st i took the overhead down and un did the homelink assembly.
2nd i took the motherboard out.
3rd i found push on push off switches from radio shack small ones with red button
4th installed the switches into the assembly that used to house the mother board
"keep in mind this took roughly 5 hours of trial and error
to get to this stage i ended up having to take the radio shack switches and shaving the push buttons down a little bit so that they could fit behind the homelink buttons
5th went and wired the main hot wire to the switches then and the lead wire to the strobes. and then on the same side as the lead wire to the strobes i ran a wire to 3 leds and installed them in the whole where the indicater light was for the home link. this way its much brighter and white led much cleaner looking.
6th tested everything out and popped it back up in the ceiling and wow awsome results.
I will get some final pics tomorrow but dont have any install pics the girl had the camara.
But let me stress this was very time consuming and took a lot of trial and error but if i was to go do it again i woul prob beable to do it in about 1 hour that cause i learned from my mistakes lol
