that is a project of mine - wiring in a Mark VIII e-fan using 4 relays and two temp (coolant) sensors...it automates the entire system to turn on low speed at one temp, and high speed for another.
I tested it on Sunday and it worked well. This weekend i'm tightening everything up so it looks clean and the temporary connections will be replaced with permanent.
that sounds pretty sweet you should do a write up
