First rear diff now transmission
Chetrick87
I just got my truck back from having the rear diff rebuilt and tranny lines put on. It was driving ok for about an hour of running around. I came out of a store. I pulled away amd it wouldnt shift into 2nd. Then finally it jerked into it with loud clunks and jerking. I pulled over. I went to take off again and it just revved up and wouldnt move. Reverse worked along with 1, 2, and 3 but nothing in drive. I checked the fluid and it read that it was full
Mechanic sent someone and he said that the line cracked. They towed it back to the shop. Today he told me he replaced the lines and flushed the fluid which was clean ans changed the filter. Put it all back together and still the same problem. Any thoughts????
Tractoman
If it's a line they replaced (assuming trans fluid lines) that cracked, that may have caused the failure? Have you discussed that with them?
Chetrick87
Chetrick87
He said that he had his cpu hooked up and checked the solenoids. The one for first gear isnt responding/clicking but all the others are. So hes chabging it on monday. If not i was tild it could be the forward sprag assenbly in the tranny. When the line cracked the fluid was still high so idk
Chetrick87
Chetrick87
He dropped the pan then hooked his cpu again. Now the solenoid for first is responding. So hes thinking maybe a wire is getting pinched or something when everything is together. If thats not the case then its going to a transmission shop
