foctory alarm
qlc1964
qlc1964
hey fellas!!!! my sister has a 03 tahoe and the alarm
stop working. did the new batt on the remote still nothing.
does any know where the fuse is or the box is. thanks
BlueTahoe2001
Charlotte, NC
Does the Horn work?
The fuse box is under the hood right behind the battery. It should say it somewhere on the box whats under there. When you pull the cover off, there will be a diagram which shows you what each fuse is.
Also, when you open the drivers door, there is a small triangle looking panel on the side of the dash, that pops off and there is also fuses under there as well.
BTW, Get yourself a test light, It will make checking the fuses 10x's faster than pulling one out and seeing if it blown.
Yukin Toad
