Fog Lamp Conversion
NELLY1947
On my 2023 Yukon Denali XL I would like to get more front lighting. Has anyone found a replacement fog light where I can change the LED lamps for a higher lumen out put. The ones on my truck are sealed.
none of the heavy hitters make anything that is plug-n-play for these trucks, you would have to go with a generic design led light bar or whatever that you could either fit behind the grill or in the bumper somewhere. In a sense that makes it easier to just add-on lighting as desired. Ideal form factor is a FOG pattern not a SPOT pattern and 98% of them are SPOT pattern or simply do not say in which case expect it to be SPOT pattern.
if a diode dynamics pod will fit then you would just need to make your own bracket.
if you can make a pod fit then this is the difference it makes, top without fog on, bottom with fog on.
darkvader562
