Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
I just bought an H3 foglight kit on ebay, it came and i went to install it and the wire just plain out don't look right. it's not just plug and play like my hid kit for my low beams was. I really need help on this and it's a 99 yukon denali
nope, I've tried everything and nothing is working, i think theres something wrong with the company i bought it from. I ordered a pair of 9006 bulbs and they don't even work, but they're the right size.
In some cases you have to trim the bulb socket just a bit to make them fit in the housings. If you can't make them fit with minor trimming, you might have the wrong bulb size. Sometimes they send you extra wiring that you don't need. Do you think you can make it work if you take off the 2 wires with the spade plugs? That should plug into your stock wiring if they sent you the correct kit.
I contacted the company and I'm just going to get a refund so I don't want to mess with it until I get the issues resolved. If i can't return it then il try what u suggested
you need 880 bulbs not H3 or 9006.
And like said, reverse the power plug and it will work.
Btw ALL 88X bulb types are the same base (LUGS) type.
In Halogen bulbs 880 is 25watt 883 is 37.5 watt.. with straight base, meaning wires exit straight out.
Other 88X bulbs have a 90* base, for more confined mounting locations.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
