Free Travel Bump Stop
bodymccannx
Anyone know the Brand and part number for the bump stop to use when you do the free travel mod?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
mark are you on 305 35 24? if so the bumpstop modded showed will work perfectly as it did on his truck. And if needed you can cut them down the actual bolt goes 1.5 inches into the bumpstop not all the way up. Dont ask me how but I know lol
g35kid
So Cal
I guess i have this free travel bump stop all wrong but i thought when you guys lowered your truck you completely removed it
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Over 3 inches I would do it. You have to cut the bumpstop bracket off the frame not just remove the oem bumpstop
Modded
That Guy
The OE bumpstop bracket is removed (and the OE bumpstop since it attaches to the bracket) to gain more travel. Then a shorter aftermarket polyurethane stop is installed in place of the old one.
