Front Camber Bushings
B.G.
Are these DIY or is a press needed to install. Also, what is a rough estimate on what a shop would typically charge to install these. Thanks
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Need a press. How low are you?
Alex33
Not sure where you are, but I had mine pressed in for very little, maybe 30-40 bux. I took them the arms and new bushings though. It may be more if you have someone remove and install the arms.
NathanJax
Vacation Nathan
Administrator
Jax, Fl
Pushed in and cost me $60.
NJ04HOE
Paterson, NJ
I pressed mine in with a press @ my job. I'm sure it wouldn't be too much if you took the arms and bushings to a shop and had it done. Not a DIY job for sure those things are in there good.
Sent from my iPhone 4 using Tapatalk
jeffrocates
