front dif rebuild !!budget!!
clownracer
well i notced a leak coming out of the drivers side input shaft of my front Differential and when i drained the fluid a chunk of metal fell out :favorites68:
i am tied up in a nv4500 swap and cummins diesel swap im not going to be able to afford sas/14btff till next winter
how much am i looking to spend for an inexpensive diff rebuild i can probably do it my self with help so i just need parts.....i would like to also swap in new gears at the same time....
so i guess im looking for someone to point me in the direction of a cheap rebuild kit for the front and rear and a cheap gearset
i dont need super offroad performance stuff it literally has to last me untill next october when ill do it properly and swap in 1 ton stuff
_Dylan_
STAY FROSTY
Swap the whole front diff out with a junkyard unit. That is probably the cheapest.
C
clownracer
I think it's got custom gears in it now.....I'm going to pull the rear diff cover in a week to confirm
---------- Post added at 06:48 PM ---------- Previous post was at 05:44 PM ----------
if so i cant use an off the shelf diff
inthechateau
Maryland
Plenty of trucks in the yard, pull both diff's out of one truck and git'er dun
retorq
Kingman AZ
LOL Yeah go get some junk from a junk yard and throw it in our truck and hope it works.
Pull the cover and find out where that chunk came from. Could be a tooth that got sheared off, could be a spider gear issue ...
Randy's Ring and Pinion usually has the best prices.
http://www.ringpinion.com/DiffWizard.aspx
Go there, enter your specs, look up what you need. Diff rebuild kit is $130ish.
C
clownracer
just making sure you were not planning on an automatic locker in it.
nah I'm not putting any money I don't have to into these wimpy axles I'll wait till I get the one ton stuff in there then do lockers
Carlos123
