Front Door Speakers
Diller
Cedarburg, WI
Forgive me if I missed it.......I spent 45 minutes searching last night, but didn't come up with a difinitive answer.
I need to replace my head unit in my '99 Yukon SLT. I figured along with that, I should replace the front door speakers (wife doesn't need to know that!). I can't find an answer as to what fits WITHOUT modification. I've seen some say 5 1/4 and some say 6 1/2.
Also, what fits the rear doors (6 3/4?). I should be able to fit a 12" sub in those, since the window doesn't use the bottom of the door :)
quietfly
6 1/2's will fit, but you might need a spacer depending on how deep they are. mine fit fine with out one.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Front will fit with out spacers
The door openings are 6.75" but fit 6.5" just fine as well depending on speaker manufacturer. I use polk 6.5" components in all four side doors.
use crutchfields database for details.
---------- Post added at 11:55 AM ---------- Previous post was at 11:54 AM ----------
also speaker grilles will not be needed.
alc5m
i got 6.5in mb quarts the cheap component set, i love it though
but i had to use washers to space it originally then i got some half inch spacers and put it in
but i hate doing speakers on these trucks cause i hate pulling the damn panel off even though ive done it so many times i could do it in my sleep, lol
but 6.5 is the general concensus
Gzes
the drifting 2dr
Wichita tx
Atleast you have door speakers. I want to put some in my how but is there any problems if I punch a hole in it. What speaker size would work? I would put in some kickers tho but has anyone done it to a 2 door hoe yet?
patniven
