Front drive shaft u joint 4x4 Yukon
Tiberiusx
Is it ok to drive the vehicle with the front drive shft removed. . ? Only for short distance thanks..
T
Tiberiusx
Well I can answer this myself.. Yes I drove it with 4x4 shaft removed was all good I was concerned I would be loosing tc fluid...
SunlitComet
OBS Jedi-Do Good
unknown at this time.
yes it is fine. the yoke end it bolted to the front output shaft i the tcase so it wont fall out. and front diffy should be the same.
---------- Post added at 09:41 PM ---------- Previous post was at 09:40 PM ----------
axle shafts is a no go in front.
hosleyb
