Front end clunk/pop when turning left
Frey522
I've got this front end clunk. It seems to happen when turning left. It has happened when I hit the gas turning left as well as while turning left and going through a round-about/ traffic circle.
I jacked up the front to see if I could move the tire to get any sound but nothing.
Please anything will help point me in the right direction
Goodinblack
I Like Tacos
Dirty South
Check all the ball joints just to be sure as well.
May have to use a pry bar to check for movement.
afpj
U joints and possible CV joint. Just because your wheels are tight, doesn't mean the hubs aren't bad either so be careful. Check brake conponents too, (we have a floating rotor so make sure caliper is bolted to spindle well), and make sure wheel nuts torqued to spec (140 ft lbs IIRC)
Chllinone
