02Burgundybeast
Driving home the other night with the windows down and I noticed a slight squeak coming from the front end. Didnt think much of it. Later that evening I made a sweeping right turn and noticed a popping noise and a thumping feeling from the front end. I jacked the truck up and did a shake down and that did not reveil anything.
I have been noticeing my traction control light flashing on and off when making turns and the ABS feeling in the break pedal. I went ahead and ordered a new hub for the passenger side becuase this is where the noise is most audible. I never had a CV shaft go bad on me so I am not sure what that would sound like. Any of you guys ever had these symptoms and am I on the right track?
Also, the t-case and front diff do not have any play and everything is tight when I rotate the tires off the ground. I also do not have any noise coming from the hub when rotating the tires off the ground.
Any feedback would be appreciated.
