Front end vibration only 60+mph when turning right
Brandtd
So i have a 2007 yukon denali AWD 6.2 with 121k miles, fresh trans, just got it from a dealer and it started doing a strange rumble strip type vibration only at 60+mph when turning right have to be turning the steering wheel at least 45 degrees or more to replicate it. Doesnt do it when turning left, or driving straight down the highway. Roads are smooth, doesnt happen when braking, front diff is full and clean sounds like front right area. Any help is greatly appreciated.
thompsoj22
chock the rear wheels and jack the right front wheel off the ground with the wheel at 45 degrees and rotate, maybe you can feel some roughness in the CV? it sounds like a driveshaft but the steering direction should not effect/amplify the out of balance condition? Are you running oversized tires? check for rubbing evidence on inside sidewall?
juantavarez127
