Wow, so many people talk about doing a pitman arm in 20 minutes or less... There must be something wrong with me. Granted, I'm doing tie rod ends, pitman arm, and idler arm, but that's not much more.
First I had trouble with the pitman arm to relay rod. I found out I needed a wider pickle fork, 1-1/8". Maybe I should have known that, but I rarely read about needing such a fork. Then I had trouble with removing the inner tie rod. I finally got it with a little more torque on the end of my crescent wrench. That took a couple of hours to accomplish, mostly finding a suitable pry to stick on the end. Then I had to remove the pitman arm nut. Another couple of hours, finally a stronger neighbor came along and just got it with a little extra leverage.
Now I'm trying to remove the pitman arm. I have this: http://www.lislecorp.com/divisions/products/?product=245&jsn=271
but the claws won't fit around the shaft between the pitman arm and the steering gear. I'm having to file the gap wider. I know some one used a pickle fork on this, but I'm not comfortable using such a tool near the splines. I tried the Proto 2-arm gear puller, but I was afraid it was going to break. Also, my air for my impact isn't strong enough for this job I think. The only way I can get more air is to upgrade to 220V, and I'm not going to go into that expense. I'm just about ready to remove the entire steering gear and take it to a shop to have them swap the pitman arm for me.
Some guys seem to get this job done in a matter of a few hours. This it getting into days now.
Larry
Larry
