Front Shock
insadj05
Iowa
Replaced the shocks on my 99 Tahoe. This winter I noticed a noise coming from the right front. Too cold to work outside I took it to a shop and they said it was clicking. These are Reflex's took it off and replaced it from Oreilly's. Went down the lane yesterday after replacing and its still making noise. Checked it and the upper mount is loose. I can turn it slightly. The drivers side is tight. Do I not have this tight enough? The bolt doesn't look bent or worn!
Any ideas would be great. Thanks for your help.
I
insadj05
Iowa
Thanks sunlit. Makes a difference when you can get the right amount of torque on the bolt.
