front shocks.worn..need replacement advice
Ant
I have a 05 Yukon slt with autoride and my front shocks are worn out what's a good replacement for a reasonable price
A
Ant
stock height?
Yes, stock height with autoride, does that require a special shock for the front? the back one look fine they actually look like theyve been replaced before but could i put like a rancho 5000 series on there? or something similar?
ghostworks
Norway
I think some Denali models have special front shocks, but if you just have regular autoride then you can replace it with Bilsteins regular shocks. My Tahoe with autoride only have auto leveling in the rear.
91RS
GA
You have to use the correct shocks, you can't just use regular shocks. The fronts are adjustable dampening with the Autoride system. Napa has the correct shocks.
A
Ant
You were right but I had already installed the new standard shocks , now have the service autoride light on dash, so I searched and found you can remove rtd fuse to get rid of light but I only replaced the front two so how can I lose the light ?
Ironman1979
Odessa, TX
replace the ones you just put on with the adjustable dampening ones that are for your truck.. or it will just continually re-throw the code
drewxjn
Irmo, SC
They are probably electric shocks. The only way to not have the service air ride display is replace with stock shocks or solder a resistor in the plug for the shocks.
Mxb177
