LSBoostedModular
- Joined
- Apr 7, 2024
- Posts
- 10
- Reaction score
- 0
Hello everyone.
First of thank you to the members that posted about the H3 engine mount. Thank you
I have read and found out the torque specs on here for front suspension. But haven’t found anything out about torque procedure. When tightening the upper and lower ball joints is it supposed to have load “jacked up on control arm to load”
Lower control arm to frame supposed to be loaded when torqued to 129ftlbs
Or is just the upper control arm bolted to frame the only part that is loaded when torquing to 140 ftlbs? Everything else just torqued with no load. I def want to get the torque correct as I don’t want to make a mistakes on ball joints
Thank you in advance - Jason
