Front washer fluid wont spray
woodrep
I'm trying to chase this one down. My rear washer fluid will spray, but my fronts arent activating. When you push the switch to activate them you can't hear the motor run, but when you activate the rear control it works. Help?
W
woodrep
Bump. Any suggestions why the back window sprays, but the front windshield doesnt? Surely its one pump right?
longstand
I similar problem before. make sure you check if the hose is connected to the Spayer near the hood.
or DO THIS:
OPEN THE HOOD
TURn on Spay
Look for any water leaking Hood, follow it
96ProCompTahoe
IN
If our trucks have seperate pumps for the front and rear it sounds like you have a bad connection or a burned out motor for the sprayers. i have yet to dig mine out from under the second battery tray, so i may be wrong.
Bnels82
