I recently tried to use my 4 wheel drive and when it engaged the front tires started hopping and skipping and the truck pulled to the side quite violently.
i was going around 25mph on a very snow covered slick road. I had a bad cv
shaft so i chalked it up to that.
Well, today I replaced that bad shaft and took it out to see if that fixed my problem....it didn't at all. I did test it on dry pavement but this isn't a normal
4wd feeling. As soon as the front diff locks in and the light on the floor shifter stays solid the front wheels literally stop the truck it will actually drag the front tires, it feels as though the front diff. sticks so badly that the wheels cant spin. I decided to try 4 low and that seems fine it engages just fine and the truck sounds normal, and you can tell the front wheels are spinning freely.
I'm not well versed in the 4x4 end of things so i'm not sure where to even start.
I swapped out the transfer case last winter and everything worked fine after the swap. I rarely use the 4wheel on my tahoe but need to get this fixed.
Just some info. I swapped the rear end and transfer case out of the exact same year and body style as my own truck. 1995 2 door Tahoe. i also have a 2 inch torsion bar lift with blocks. I thought maybe the front shafts were tweaked to much so i lowered the front down about 3/4 of and inch, the cv boots are not angled to bad( the pleats on the boots dont rub against each other). I'm guessing that I have a front diff problem or a transfer case problem.
Any ideas for troubleshooting would be great.
