Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Has anyone on here changed the fuel door spring on there hoe? I'll be attempting it this weekend just wondering if there is anything I should look out for.
I haven't but I am needing the same thing done. It looks as though the spring for the door is about 8 bucks on eBay. Just didn't know if it was much to it.
Well I pulled off the door today and all I did was remove the 2 bolts holding the door on and remove the 2 bolts holding the plastic on. As you can see the spring is fine but it's my door hinge that broke.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
