Fuel injectors
knotty
Does anyone have a how to on changing fuel injectors on a 96 hoe ?
thanks
bai78
Surviving
Dallas, TX
You'll have to pull the manifold off & change out the spider injectors.
K
knotty
do you have to pull out the dist. also ?
JP422
Southbay, CA
Yes... I believe the distributor has to come off to remove the manifold...
Mark the distributor and its placement well.. it's a b*tch if you can't get it re-aligned after.
rucr8z2
Saluda,Va.
no you don't have to pull the distributor just unbolt the two nuts holding the fuel lines into the top of the plastic intake. there is also a 13mm bolt holding down the fuel lines beside the distributor (semi hard to get to). Then pull the harness out of the top,then all of the nuts and bolts holding the upper plastic plenum down-also a couple of sensors etc...then you will see the injector spider system....
Roblusk
