Fuel pump ground
z86trev
Long Island NY
Did the fuel pump last Thursday and truck has been fine since. I came out of the store today and no start. Wouldn't even turn over with starting fluid. I'm thinking its q bad ground. 2002 suburban flex.
Thanks for any guidance
Rivieraracing
Are you saying that it won't even turn over at all or it just wont' start with starter fluid?
Z
z86trev
Long Island NY
It actually ran with starting fluid. I do not hear the pump kick on. It just cranks when the key is turned, nothing comes. Out of the Schraeder valve either.
Rivieraracing
Might find the fuse for the fuel pump and make sure it's still good, if its good then find the relay and see if you get power going to it when the truck is in the On position.
Also, try going under the truck and smacking the bottom of the fuel tank a couple of times with your fist and then go try starting the truck!
irochj
