Fuel tank leaking
woody367
So on my 99 Yukon it has a fuel leak towards the top of the tank. I was looking for a new one but can not find a replacement tank that fits inside frame rail on drivers side. I can find a ton for behind rear axle center mount.. Is thare a repair lit that is ment just for these tanks? I am starting to have issuse with the fuwl pump so would like to repair the leak while the tank is down. Thanks
exp500
Try LMC truck. There are a few threads here about your tank but I dont remember details- 2 door/4door etc.
Could be just fuel pump or hose leaking. Look first.
1BADI5
DMV
I went down this road with my 99 Yukon.
The 4 metal clips the fuel pump on the top of the gas tank rust out and the fuel pump assembly lifts up out of the gas tank. The metal clips are molded into the plastic gas tank; so once they rot out the tank is NFG.
I had to source a used tank because there was not a single new one to be found. SO start looking for a southern junk yard/salvage yard to get a tank. The used tank with shipping still cost me nearly $400 back in 2016.
woody367
woody367
Mine is a 4 door. I do not know the part# will have to call a deal;er I guess. Was hoping there would be a way to repair it.
bill1013
Waianae, Hawaii
Here's my advice on this subject. My 99 Tahoe LT 4WD had similar problems. The fuel pump inside failed (of course it was just I after I filled her up!) and the neck had a crack in it. It wasn't a constant leak, but sometimes when I refueled it leaked like a sieve. So I take her to my mechanic, who retired and closed shop around a year later, says that he can use/transfer the parts from inside the old tank to the new one. And it would have saved me a hole mess of green if I did, but I'm old school and I told him to change everything and let's start new. He pointed out that my 99 Tahoe (145K mi.) was 16 years old but in the prime of life. So I went with his decision, which turned out to be a big mistake. The fuel sensors in the tank went out around 1k miles later and my gauge would only read full, so I never knew if I was going to run out of gas. I used the trip meter to estimate the MPG and would fill up accordingly. It was a pain in the ass. Worst yet it ended up costing me more to have it repaired the second time than the first. The moral of the story (I guess) is the sensors and components, which are made of plastic & cheap aluminum, are submerged in a tank of caustic liquid (gasoline) 24/7 and if the tank is leaking it may be a sign of what's going on inside the tank. Thought of that after the second repair as I was trying to figure out how to pay for it. Hindsight is 20/20! Go figure!
woody367
woody367
Well the leak has been there for almost a year but just did not fill it upmall the way. Now I am starting to have fuel pump issue's so if I have to change the pump I should fix the leak.
bill1013
Waianae, Hawaii
My 99 had 3 fuel pumps. One inside the tank, which pumped the fuel to the one right outside the tank, which pumped it to the one on the engine that fed the "spider". I replaced the "spider" long before the tank. The problem with the one in the tank is you have to "Disturb" the equipment in the tank, which has been sitting undisturbed, in that caustic liquid I mentioned earlier, for years. Seems the smallest disturbance sets off a chain reaction whereas it all goes to shit eventually. IMO, if you're going to drop the tank and open it up for the fuel pump you're opening a can of worms that will eventually bite you square in the ass. I still have scars!! And they sting!!
GoToGuyRon
You have three fuel pumps on a 1999 Tahoe... . I need to look this up.
Squirrely tahoe
