Fuel vacuum hose
jcevans7
Friendswood, TX
Looking for a fuel vacuum hose. Was tue only victim when I replace my knock sensors. Made a field fix with heat shrink tube but that is failing fast. In the diagram it's number 26
Also gave another pic from Google if anyone has parts I'll gladly pay. Pick and pull out here net 0 results
Sent from my SM-N910T using Tapatalk
SLCHOE
ASE Master Certified + (L1)
Midvale, Utah
So I assume the brittle plastic line broke? If you still have both ends just get a few inch long pice of vacuum hose from the local parts store and insert both broken ends into it. You want it to be a snug fit so get the right diameter and use some silicone spray to slip them together.
jcevans7
jcevans7
Friendswood, TX
I'll grab some hose when I get off my shift. See how it goes.
SLCHOE
Midvale, Utah
Take the broken line with you and match it up. vacuum line is sold by the foot and is pretty cheap.
jcevans7
jcevans7
Friendswood, TX
Solid. It would've taken me a minute to think of that. Coming off nights the mind is never as sharp as it should be.
shanersutherland1
