Yes, this has been discussed all over the interwebz. This thread is mainly for consolidation and confirmation of info.
I'm considering swapping in a 5.3 or 6.0 Gen3 motor because I often find sub-100K to 150K mile units for $300-$700. I'm looking only at ones that are still in the vehicles so they can be ran and tested. I'm considering going this route instead of an AFM delete on my nearly-200K-mile Gen4. Of course, I'd inspect and test it as much as possible since I wouldn't know the history of it. My general idea is to get one from a clean and well-maintained SUV as these have a much lower chance of being abused.
I know the main functional differences are the 24X reluctor wheel on the crank, the cam sensor is in the front and the knock sensors are on the sides of the block. I'll swap my current timing cover over and screw the knock sensors into some unused bosses on the sides or drill and tap to put them into the same locations as they are on the Gen4. For the reluctor wheel, a buddy is "downgrading" a Gen4 he got a deal on to run on Gen3 electronics for his rock crawler rig and said I can have the 58x wheel.
I know the later blocks (2005?) have bigger/stronger rods and floating pins like my Gen4 and I plan to get one of these. I would also reseal it, replace the barbell, etc. before swapping it in. My questions are:
1) Are there any considerable strength differences in the blocks and/or would I be giving up anything else?
2) Could I remove the crank, swap the reluctor wheel and reinstall it (with new ARP and/or Katech hardware) while keeping everything (bearings, rod caps, etc.) in it's original location with no problem? My first thought is that this is a reckless idea and puts me at risk for a spun rod or main bearing. But, I read and hear of many doing exactly this with no problems as long as they follow the hardware torquing specs to a "T". I have a quality torque wrench with very little use and even lesser use since being tested and certified by a lab.
