GeorgeB’s 2013 Suburban LTZ “Fin”
George B
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
I just did mine in October at 138k. I had bad upper/lower ball joints and a bad inner tie rod. I replaced entire control arms both upper and lower and inner/outer tie rods on both sides. The wheel bearings are still good, so didn't mess with them, but the front brake pads were toast so replaced the pads and rotors a couple weeks later.
You use Moog or ACDelco?
George B
George B
¯\_(ツ)_/¯
On my third tank of non-ethanol 91 and fuel composition was reading 4%. Reset it with mu Tech2 and it only changed down to 3%. Not sure if that is correct or not. I went from 70% on E85 down to the 4% in just two tanks full.
Going back to the 88 oct E-15% or E85. this stuff is too expensive to run consistently!
kbuskill
NE. FL.
The Tech 2 always resets it to 3%. That is normal.
George B
George B
¯\_(ツ)_/¯
Noticed an odd behavior.
1/4 tank of fuel
Coasting down from 50mph into a right turn with a yield. When I get back on the the throttle I experience a hesitation to accelerate. Once the trans figures out it need to downshift the truck goes as it should.
Seems to only happen at or below 1/4 tank.
I am going to try to record a snapshot of the fuel data tomorrow before I fill up. Not sure if I can record the trans data at the same time or not.
ToddYYC
