GM Bolt pattern Guide
WiCK3D_SiX
Mount Joy, PA
Thought this would come in handy for anyone looking for factory wheels from another vehicle.
http://www.vehicle-bolt-pattern.com/chevy-lug-reference-guide.html
Chevy Bolt Pattern Guide
The bolt pattern, lug pattern, or bolt circle is the diameter of an imaginary circle formed by the centers of the wheel lugs. Bolt patterns can be 4, 5, 6, or 8 lug holes. A bolt circle of 4x100 would indicate a 4 lug pattern on a circle with a diameter of 100mm. The bolt pattern is comprised of two numbers - the first indicates how many bolt holes are on the wheel, and the other describes how far apart they are. A bolt pattern of 5-115mm would mean the wheel has five bolt holes and they are 115mm apart (measured across the center of the wheel). Dual Bolt Pattern: More and more manufacturers are building their wheels with two bolt patterns. This expands the number of fitments the wheel applies to. For example: a wheel with a 4-100/114.3 bolt pattern has 8 lug holes and will fit both 4-100mm and 4-114.3mm fitments. Measuring a 5-bolt pattern: A 5-bolt pattern is very difficult to measure without using a bolt pattern gauge. Basically, you would measure the diameter of a circle that crosses through the center of the lug holes. This method is not recommended to confirm wheel fitment. Please use the below as a reference only.
Chevy Lug Pattern Reference
MODEL
YEAR
SIZE
P.C.D.
LUG SIZE
MM
OS
ALL MID & FULL SIZE RWD
55-88
14",15"
5X120.7
7/16-RH
L
WAGONS & HD models
55-95
15"
5X127.0
1/2-RH
L
BELAIR,BISCAYNE
77-87
15 X 7
5X120.7
7/16-RH
L
BERETTA
87-on
13 X 5.5
5X100
12mmX1.5
57.1
H
CAMARO
82-92
15 X 7
5X120.7
12mmX1.5
L
CAMARO
93-on
16 X 7.5
5X120.7
12mmX1.5
70.3
H
CAMARO,IROC Z
85-92
16 X 8
5X120.7
12mmX1.5
L/M
CAMARO Z-28
93-on
16 X 8
5X120.7
12mmX1.5
70.3
H
CAPRICE CLASSIC
90-97
15 X 7
5X127.0
12mmX1.5
L
CAVALIER
80-on
14 X 6
5X100
12mmX1.5
57.1
H
CELEBRITY
80-89
13 X 5.5
5X100
12mmX1.5
57.1
H
CELEBRITY EUROSPORT
82-89
14 X 6
5X115
12mmX1.5
70.3
H
CHEVETTE
75-86
13 X 5
4X100
12mmX1.5
57.1
H
CITATION
80-86
13 X 5.5
5X100
12mmX1.5
57.1
H
CORSICA
87-on
15 X 6
5X100
12mmX1.5
57.1
H
CORVETTE
68-82
15 X 8
5X120.7
7/16-RH
L
CORVETTE
84-87
16 X 9.5
5X120.7
12mmX1.5
M
CORVETTE
88-89
16 X 9.5
5X120.7
12mmX1.5
M
CORVETTE
90-96
17 X 9.5
5X120.7
12mmX1.5
H
CORVETTE
93-96
17 X 8.5
5X120.7
12mmX1.5
H
CORVETTE ZR1
91-on
17 X 9.5F
5X120.7
12mmX1.5
H
CORVETTE ZR1
91-on
17 X 11R
5X120.7
12mmX1.5
H
IMPALA,CAPRIC
77-87
15 X 7
5X120.7
7/16-RH
L
IMPALA
99- on
15 X 6
5X115
12mmX1.5
70.3
H
IMPALA SS
94-97
16X8
5X127.0
12MMX1.5RH
L
LUMINA
90-on
15 X 6
5X115
12mmX1.5
70.3
H
LUMINA
90-on
16 X 6.5(OPT.)
5X115
12mmX1.5
70.3
H
MALIBU
97-on
15 X 7
5X115
12MMX1.5
70.3
H
MONTE CARLO
95-on
15 X 6
5X115
12mmX1.5
70.3
M
MONTE CARLO
95-on
16 X 6.5(OPT.)
5X115
12mmX1.5
70.3
H
NOVA/SPECTRUM
86-89
13 X 5.5
4X100
12mmX1.5
H
PRIZM
90-on
14 X 5.5
4X100
10mmX1.25
H
SPRINT
88-89
12 X 4
4X114.3
10mmX1.25
H
VENTURE
97-on
15 X 6
5x115
12mmX1.5
70.3
H
CHEVROLET/GMC TRUCK/VAN/SUV
1/2 TON BLAZER, JIMMY, SUB FULL SIZE 2X4
71-91
15 X 6(7)
5X127.0
1/2-RH
L
1/2 TON BLAZER, JIMMY, SUB FULL SIZE 4x4
71-91
15 X 7
6X139.7
7/16-RH
L
1/2 TON BLAZER, JIMMY, SUBURBAN,
TAHOE, YUKON, DENALI FULL SIZE 4X4
92-on
16x7
6X139.7
14mmX1.5
78.3
M
TAHOE, YUKON 2X4
92-99
15 X 6(7)
5X127.0
14mmX1.5
L
TAHOE, YUKON 2X4
00-on
15 X 6(7)
6X139.7
14mmX1.5
78.3
L
1/2 TON TRUCK ALL MODELS 2X4
67-87
15 X 6(7)
5X127.0
1/2-RH
L
88-98
15 X 6(7)
5X127.0
14mmX1.5
L
1/2 TON TRUCK ALL MODELS 4X4
67-87
15 X 7
6X139.7
7/16-RH
L
88-98
16x7
6X139.7
14mmX1.5
78.3
M
1/2 TON TRUCKS 2X4 & 4X4
99-ON
16X7
6X139.7
14mmX1.5
78.3
M
3/4 TON TRUCK 2X4 & 4X4
67-ON
16X7
6X139.7
1/2 or 14mm
L
ASTRO/SAFARI
85-on
15 X 6
5X127.0
1/2-RH or
L
AVALANCHE
02-on
16X7
6X139.7
14mmX1.5
78.3
CYCLONE, TYPHOON
ALL
16 X 8
5X120.7
12mmX1.5
H
EL CAMINO, CABALLERO
64-81
14 X 6
5X120.7
7/16-RH
L
82-87
14 X 6
5X120.7
12mmX1.5
L
ENVOY
02-on
16X7
6X127
12mmX1.5
78.3
H
LUMINA APV
90-96
14 X 6
5X115
12mmX1.5
70.3
H
S-10, S-15 BLAZER, JIMMY,
SONOMA 2X4 MID SIZE
82-on
15 X 7
5X120.7
12mmX1.5
L
SONOMA 4X4 MID SIZE
83-on
15 X 6
5X120.7
12mmX1.5
H
SAVANA 1500
01-on
16X6
5X127.0
14mmX1.5
TRACKER
98-on
15 X 6
5X139.7
12mmX1.25
L/M
TRAILBLAZER
02-
16X7
6X127
12mmX1.5
78.3
H
VAN G-SERIES 1/2 TON
71-96
15 X 6
5X127.0
1/2-RH
L
The offset of a wheel is the distance from the mounting surface of the wheel to the true centerline of the rim. A positive offset means the mounting surface of the wheel is positioned in front of the true centerline of the rim / tire assembly. This in effect brings the tire in to the fender well more. Conversely, a negative offset means the mounting surface of the wheel is behind the true centerline of the rim / tire assembly. This will cause the tire to stick out away from the vehicle.
H = High Positive or FWD (Front Wheel Drive) typically +45,40,35 offsets
M = Medium Offset or RWD (Rear Wheel Drive) Typically +20 offset
L = Low Offset or RWD (Rear Wheel Drive) Typically 0 offset
Plus sizing your wheel & tire combination was designed to enhance vehicle performance and looks by allowing fitment of larger diameter rims and lower profile tires. The theory is that while making these changes, you keep the overall tire diameter within 3% of the original equipment tires. This is important because larger variances can cause problems with transmission shift points which can decrease fuel mileage. It can also confuse braking system computers which can even lead to brake failure.
Here's the rule of thumb for "plus sizing":
Plus 1:
Increase section width by 10mm
Decrease aspect ratio by 10 points
Increase rim diameter by 1 inch
Plus 2:
Increase section width by 20mm
Decrease aspect ratio by 20 points
Increase rim diameter by 2 inches.
This is not exact, but it will usually get you in the right ballpark. We always recommend consulting with the people you are purchasing the wheels and tires from to ensure fitment.
Centerbore relates to the center hole in the wheel that centers the wheel on the hub of the car. Since most wheels are mass produced, they have a large center bore to accommodate several different vehicles. If this is the case, it is recommended that you use a hub ring. Hub rings are hard plastic or metal ring that fits between the wheel and the vehicle. This centers the wheel perfectly on the hub ensuring that there is no run out when the wheel is installed on to the vehicle. Without hub rings it is possible to get vibrations even if the wheel / tire assembly is perfectly balanced.
Torque: All alloy wheels should be installed using a torque wrench. This ensures that the wheels are not too tight or too loose. Check your vehicle's manual for correct settings. When you install wheels for the first time, you should re-torque wheels after about 100km to 150km (60 to 90 miles). Always refer to Owner's Manual for proper factory specifications that take precedence over the listed recommendations. 12mm = 70~80, 7/16" = 55~65, 1/2" = 75~85, 14mm = 85~95, 9/16" = 95~115, 5/8" =135~145.
bowtiefreak
No Quarter
Near Philly
Nice post.
Note about hub rings....from my understanding and reading, metal units can have a chance to corrode and fuse to the wheel or hub. Some peope prefer plastic for that reason.
NH-Yukon
