GMC Yukon Denali 2016 - Water coming through roof while sunroof closed
2015Denali4WD
I have an 2016 Yukon Denali where water is leaking through the top speaker vinyl of my roof and pouring onto the dashboard and radio navigation area to my cupholders when it rains. My sunroof is closed during the entire time. I need helppppppppp.
Also I cant open up any doors to my truck with my key fob. I have to use the metal key to open the doors and the alarm goes off.
I tried starting it up and the truck said it doesn't recognize the key fob.
I drove it to work yesterday morning and it was fine. This is the first time it hasn't worked when it rains.
dbbd1
The shark fin antenna, no doubt.
There's a TSB on it.
Coronado126
ND
If you're in warranty that answers that, but if not, you'll need to drop the headliner and fix that antenna. I haven't read up on the TSB but I'm it's either a failed seal, or loose mounting nut.
2015Denali4WD
2015Denali4WD
No I'm not under warranty at all. I will take it to the dealer so they can take an look at it.
David Kriss
You should also check the sunroof drains. I have to clean the drains on my wife's 2001 at least once a year.
memakos
