going to change trans fluid and filter -- two questions
strad
Las Vegas
2005 Escalade ESV AWD with 6.0. Has tow package. All stock. First question, on my 1999 Tahoe I have to unbolt the rear mount of the trans and lift the whole package up slightly to clear the exhaust with the pan. Escalade looks similar but not exactly the same. Will I have to do that here as well?
2nd question: what transmission is this beast likely to have. 4L65E? I'm guessing it is not a 4L60E only because it behaves quite differently than my Tahoe's. And how can I identify definitively? I know to count the bolts. Anything else?
Trying to minimize downtime -- it does happen to be my work truck lol.
TheAutumnWind
How To: 4l60e Transmission Flush/Filter Change
http://www.gmfullsize.com/forum/showthread.php?t=179148
You have a 4l65e. It is VERY similar to a 4l60e.
You might consider a few things while your doing this. An external filter can be much more efficient to change, I am installing sonnax line pressure booster, Sonnax 4L60-E 4L65-E 4L70-E Pinless Forward Accumulator Piston Kit/ Sonnax 1-2 4L60 4L60E 4L65-E & 4L70-E Pinless Accumulator Piston Kit, and I already put in a larger trans cooler and Corvette servo.
Cheap insurance on an aging trans IMHO.
ezdaar
Chat Troll
Redneck central, Aka Houston
No need. Just use the flush method and let it dump the pan into a bucket.
Then you drop a empty pan.
No need for a drain that still leaves a quart in the pan.
TheAutumnWind
I guess that is a good point.
Sent from my HTCONE using Tapatalk
S
strad
Las Vegas
Thanks guys. Ordered the AC Delco filter kit for the trans. Should be here 9 AM tomorrow. Owner's manual says Dex III for this? I would have thought Dex VI. . .
TheAutumnWind
you can use vi
its compatible.
dex vi is the dealer fill now
S
strad
Las Vegas
Haha saw on another thread to look for the M32 code in the glove box. This truck does indeed have the M32 code. Thanks for the info re: Dex VI
4WDTRK
sleeps in garage
Socal dreaming of Norcal
To add to this thread...what interval do you guys do your changes at? Owners manual says 50k, Haynes says 30k or severe use 15k. Curious to know what a good rule of thumb would be?
mecanico448
