SunlitComet
OBS Jedi-Do Good
currently wearing lt245/75r16 at 40 psi. Higher? lower? don't mind the bumpiness but do want the least amount of resistance with even tread wear.
Read the fine print on the side of your tires.
No matter what size or rated tire you have, unless you have added tons of weight to the vehicle, you should always run your tires at factory rates psi.
sparg93 said:+1
Every tire is different, it will say the max PSI on your sidewall.
As an example - if you ran 50psi cold on some LT tires, by the time they warm up you could be seriously risking a blowout...others however, love high PSI.
Actually sparg, what I was trying to get across is that while most tires have a different max psi, they all state to use the psi rated for your vehicle (the one in the door jamb). They also say in fine print to use the tire pressure located on the vehicles tire placard or owners manual.
That pressure is going to be the best for the vehicle because tire pressure is basically a measure of resistance between the road and the weight of your vehicle. You want to keep the resistance factory unless you add substantial amounts of weight.
