I can't make this crap up. I am currently on my 4th set of motor mounts in 40,000 miles on my '07 Tahoe with the 5.3 FFV.
First set went out just before 200k. Went to turn hard (left) into my neighborhood on a Saturday, where openings are rare, and the engine just ripped loose from the driver's side mount and flopped over to rest on the exhaust of the passenger side.
Replaced that set "right away", then had to replace the engine a couple thousand miles later when my DoD failed. When I had the engine out, I noticed one of my new mounts was torn (driver's side again). OK, the set I got didn't have heat shields and my heatshields didn't fair well on uninstall... it was a bad day . OK, so I bit the bullet and ordered dealership mounts, with heat shields, put them in with the new motor and went on my way.
At 225k, turning left out of my wife's work one day, rinse and repeat, engine resting on the passenger side exhaust. Well if the dealer mounts only lasted that long I'll give a middle finger to paying that much again. So I ordered a crappy set of amazon mounts. Waited about 5k miles to put them in... I'm gettin' real tired of this job.
Here I am at 241k and, guess what, you'll never believe it, driver's side mount has failed AGAIN! Once again, turning left under what could BARELY be called hard acceleration.
Nope, I'm done. I refuse to put the garbage factory mounts back in. I also almost-refuse to pay $400 for the only upgraded ones I can find on a quick google search (bright orange, look like plate welded construction). While it always fails on hard left turns, I am not driving THAT aggressively. I mean hell it's a 6000lbs 2WD truck that has never seen dirt and I got a 5 year old in the back when I go anywhere. I just ain't pushin' it hard enough justify these repeated failures. I don't even tow with the stupid thing. No oil leaks, no exhaust leaks, and zero modifications to the truck at all... bone stock for every square inch.
I can't think of a physical reason for them to fail other than a crappy design (always fails in the same spot where the rubber necks toward the imbedded flange that bolts to the block side mounting plate), but I'm open to suggestions if you have them. Otherwise, can someone please point me in the direction of a set of motor mounts that don't cost a fortune but will last more than 6 months?? I'm losing what little is left of my mind with this thing!
