Gotta Leak
puckhead
CO
Walked out to my truck today and saw some liquid under the truck. Found it was some oil and put in over half a quart. Cant find the leak though. Its not on the drain plug. Any ideas? Spots that are prone to leaking? I need to clean the engine and see where its leaking from probably
07Denali
Find out if it is front or rear of the motor or drivers or passenger side. Could be coming from a plethora of spots.
Thumper8302
OKC, OK
i had hit up my mechanic on this issue a month or so ago when i was having my p0430 code and i have some leaks as well...... now i have over 230xxx miles on it and it needs valve cover seals and he pointed somethin else to me...... he had another kon in the shop and i was able to look under that one as well now this may be a spot to look..... there should be a plate lookin thingy that is bolted up right above the oil filter.... im having a leak from that area as well....
