hard wire stereo....any fuse panel spots open
dudeface
calgary canada
i am installing a new stereo. trying to hard wire it so it stays on without the key in the ignition. do not want to run power a the way to the battery............so, where on the fusebox is a spot to plug the power. or am i gonna have to run power from the power locks or some shit? any extra power spots on the fuse panel at all
1996 tahoe 2 door
peace
woodman300
fusebox location
i have a 96 4dr. on mine the fuse box is on the driver's side of the engine compartment near the hood spring. if you open it up (the top lifts off) and look at the diagram on the inside of the lid you will see two fuses that are marked aux 1 and aux 2. they are the posts you see on the right hand side of the fusebox. the fuses are 30a so i think you could probabably hook up to one of the posts and run an inline fuse of the proper size for your gear. you will need to find a nut to screw onto the post though. (at least mine don't have one.
hope this helps
ford_siesta
