Justin
- Joined
- May 17, 2009
- Posts
- 136
- Reaction score
- 87
Those numbers = OUCH! I don't suppose you have pre and post tune numbers for a 6.2? If I ever get the damned transmission working right, I will be getting a programmer/tune. I was hoping for well over 300 RWHP stock, and hopefully, at least 20-30 RWHP gain after tuning? Any special instructions to the dyno guy to do this? I'm guessing traction control off and trans in manual running up in 4th gear?
Colorado Springs is around 5000' elevation which has 80% of the air density that you have at sea level, that's 20% off right there.
In addition, TRUE rwhp is always lower than what people assume they get when comparing to DynoJet numbers. This dyno he used reports actual power output, not the 18-20% inflated number of a DJ.
Unless your 6.2L is a 2wd, which most are not, you'll have a very tough time dynoing it. Transmission gear doesn't matter either aside from overloading the dyno via the torque multiplication there is no such thing as a 1:1 ratio with the 6L80E. 300+ at the wheels with any dyno shouldn't be a problem. The 2007+ 6.0L trucks regularly put out 295-300rwhp after tuning.
